Manualy adjusting winds aLoft?
http://forums.skydemon.aero/Topic9856.aspx
By Moony - 7/13/2013 7:55:59 PM
I've been using Skydemon on my Ipad and PC since a few days so I'm still kinda learning all the options it offers.
One thing that I became aware of during planning of today's flight was that the winds aloft that Skydemon downloaded where not the same as the ones reported by the meteo service here in Holland. During the flight I noticed the actual winds at my cruising altitude were indeed different and I started looking for an option in Skydemon for Ipad to overrule the winds at my altitude with a setting of my own.
Long story short, I can't find this option. I have found it in the Skydemon for PC (its under weather->enroute conditions) but then you have to adapt for each leg individually which is a bit cumbersome, and you have to do it before the actual flight.
For the Ipad version I have not been able to find an option to overrule the automatically downloaded winds aloft at all.
As it is quite likely that I'm still missing something in this great program I thought I'd ask the veteran users on this board Smile
- Is there a possibility in Skydemon for PC to overrule the winds at cruising altitude for all legs at the same time (so not per individual leg)
and more importantly.
- Is there a possibility in Skydemon for Ipad to manually adjust the winds at cruising altitude during navigation (and thus updates the PLOG accordingly)?
By Tim Dawson - 8/7/2013 3:40:08 PM
You are correct, and your suggestion is noted. It is likely that we will implement it in the future.
