No Cloud Service / NOTAMS
http://forums.skydemon.aero/Topic9576.aspx
By HardyK - 6/10/2013 11:28:53 AM
Hi All,
I just started using SD and this morning I tried to plot a simple route, Wellesbourne to Shobdon. There are two problems but I am not sure if they are related:
(1) I can't save my route to the cloud. I get:
"This functionality cannot be used as an internet connection is not available or the cloud storage service is busy".
(2) Even though I plotted a route, the NOTAMS window:
"Your NOTAM briefing will appear here when you have plotted a route or specified a search area"
- Can you confirm if the above problems are related?
- Can you confirm if this is my error or is there some problem with SkyDemon internet services?
- If the latter, is this kind of thing frequent and how long does it usually last?
- Is there a SD service status page where I can check if there is a problem without resorting to a forum post or email?
Thank you very much.
By HardyK - 6/10/2013 11:47:45 AM
Problem solved: For some reason it was in Offline Mode.
Maybe the "No Cloud Service" warning dialogue box could suggest this as a cause?
