iPad 4 / Garmin GLO
http://forums.skydemon.aero/Topic9249.aspx
By AlanG - 5/14/2013 12:34:14 PM
Hi All,
I’ve got an iPad 4 with in-built GPS and I’m looking to get the SD application on a 30-day trial and then if all is ok to purchase SD.
I’ve come across a couple of reports that suggest the GPS within the iPad 4 may be a little limited and an external GPS unit paired with the iPad 4 might be a better solution. Amongst those suggested are the Garmin GLO, having the advantage of a GLONASS capability. This is a Bluetooth option rather then a direct plug in to the iPad 4, as would be the case with something like Bad Elf.
Anyone used the iPad 4 / Garmin GLO combination? and if so any feedback would be much appreciated.
Regards,
Alan G.
By Runways - 5/14/2013 8:18:46 PM
Many thanks nje for the tip. I will try that next. I feel my device stopped charging after a couple of trips.
I may need to dismantle it to ensure that the battery connectors are in place.
