By ckurz7000 - 5/9/2013 5:49:44 PM
I would like to put my vote in for a new function which should be very easy to implement. When planning a longer trip I had initially split it up into two legs and saved each leg as a separate route. I then decided to look at the whole trip, with the two routes joined into one, and found that it wasn't possible to join routes.
Other example at hand: I am planning a long trip through Croatia, Slovenia, Italy, Austria and Germany. There are 16 individual legs to it. I would like to see the entire trip as one route on my PC but don't feel like re-planning all of them at once into one route.
If there were a button under the Route menu which would say "Merge route..." or "Append to route..." and which would make a single route out of the one in memory and the one being opened, that would be great. In case the end of one route does not coincide with the beginning of the other route, you could simple create a straight line leg between them and let the user deal with it.
That ought to be simple and also useful.
Thanks, -- Chris.
By Tim Dawson - 5/15/2013 1:03:21 PM
Steve's right, to implement this properly would be a non-trivial amount of work. Frankly, even if it was trivial, we wouldn't implement it (at this stage) because so far I think this is the only request for it, and we want to keep the addition of extra features that are not targetted at the majority of customers to a minimum.
