SkyDemon 2.6.2.0 crash on Windows 8 64bit when attempting to print Plog
http://forums.skydemon.aero/Topic9107.aspx
By PompeyPaul - 5/3/2013 1:18:01 PM
Looks like I'm missing some sort of font. Did a search for this on forums but couldn't find any work arounds.
System.ArgumentNullException: Value cannot be null.
Parameter name: font
at System.Drawing.Graphics.MeasureString(String text, Font font, SizeF layoutArea, StringFormat stringFormat)
at System.Drawing.Graphics.MeasureString(String text, Font font, Int32 width, StringFormat format)
at Divelements.SkyDemon.Drawing.x50bfd60dff3f602d.xbf83406974150862(Graphics x41347a961b838962, String xb41faee6912a2313, Font x26094932cf7a9139, x92dcbe6bbdd0f056 xae3b2752a89e7464)
at Divelements.SkyDemon.Drawing.x50bfd60dff3f602d.xbf83406974150862(Graphics x41347a961b838962, String xb41faee6912a2313, Font x26094932cf7a9139)
at Divelements.SkyDemon.Briefing.xe5925ec7c6387d7a.xf0d36924d657c555(xc58c5603e1e3f3cc xe0292b9ed559da7d, Graphics x41347a961b838962, Rectangle x64238b90d7eeb2c8, Font x26094932cf7a9139, Int32 x555f00e49d5526af, Int32 x4a1a3d0e26dea3a7)
at Divelements.SkyDemon.Drawing.x4482359400277eba.x51d3a13ecd447601(Graphics x41347a961b838962, Font x26094932cf7a9139, Rectangle xda73fcb97c77d998)
at Divelements.SkyDemon.Briefing.xe5925ec7c6387d7a.xac394532b9695a71(Graphics x41347a961b838962, Rectangle& xa688a683bf2cfced, Int32 x278780fb19a87271)
at Divelements.SkyDemon.Briefing.xe5925ec7c6387d7a.PrintPageCore(Graphics graphics, Rectangle marginBounds, Int32 extraSpace, Boolean& hasMorePages)
at Divelements.SkyDemon.Drawing.xeed88c7e16cd03c8.x5c733725b33861d1(Graphics x41347a961b838962, Rectangle x15c6bd22a9fe622f, Int32 xcc69cbe17e053f66, Boolean& x150bab93255d8ac6)
at Divelements.SkyDemon.Drawing.xeed88c7e16cd03c8.OnPrintPage(PrintPageEventArgs e)
at System.Drawing.Printing.PrintController.PrintLoop(PrintDocument document)
at System.Drawing.Printing.PrintController.Print(PrintDocument document)
at System.Drawing.Printing.Printdocument.Print()
at System.Windows.Forms.PrintPreviewControl.ComputePreview()
at System.Windows.Forms.PrintPreviewControl.CalculatePageInfo()
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.runTryCode(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.6400 (Win8RTMGDR.050727-6400)
SkyDemon
Assembly Version: 2.6.2.17135
Win32 Version:
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.Aviation
Assembly Version: 1.0.4857.17133
Win32 Version: 1.0.4857.17133
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400)
System
Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400)
System.Drawing
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandDock.DLL
TallComponents.PDF.Rasterizer
Assembly Version: 3.0.84.2
Win32 Version: 3.0.84.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/TallComponents.PDF.Rasterizer.DLL
System.Configuration
Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Divelements.Mapping
Assembly Version: 1.0.4857.17132
Win32 Version: 1.0.4857.17132
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
SandBar
Assembly Version: 1.4.3.2
Win32 Version: 1.4.3.2
CodeBase: file:///C:/Program%20Files%20(x86)/Divelements%20Limited/SkyDemon/SandBar.DLL
enabled.
For example:
<configuration>
</configuration>
By Tim Dawson - 5/15/2013 1:00:47 PM
This isn't as simple as a missing font I'm afraid, at least I don't think it is. With some thorough investigation we might be able to find out exactly what the problem is and display an appropriate error, but so far, this seems to be an isolated incident.
