Cannot download logs from Skymap
http://forums.skydemon.aero/Topic837.aspx
By Dave Johnson - 8/1/2010 11:21:58 AM
I have a Skymap IIIC which I connect to my notebook using a serial to USB adaptor (it appears as COM 6). I can download logs using Navbox Proplan 5, but if I try using Skydemon 1.3.2 I get an 'authentication error'. If I try to upload a route, it connects and appears to work, but only about the first half of the route is loaded.
By Tim Dawson - 8/2/2010 11:42:05 AM
This sounds like a connectivity issue, possibly related to the USB-to-serial device you're using or the baud rate set. Unfortunately without having the device present here to test with, those are the only things I can think of to check.
When we added support for the IIIc we had a device present to test with, and so far everyone using those devices has had success with the SkyDemon interface, so this case is troubling.
