Easy display of local FIS frequency
http://forums.skydemon.aero/Topic8333.aspx
By grahamb - 2/3/2013 1:06:01 PM
A long flight will often transit through several FIS areas. Whilst the frequencies for these will be shown on the PLOG, there is nothing which indicates which frequency is relavant to each leg of the route, and reference to the national AIP or Charts will be required to see which frequency is relevant to any point on a route.
Two things might be helpful:
1) a selectable overlay giving FIS areas, with call-signs and frequencies.
2) including the info relevant to the point being right-clicked/touched in the 'Leg Properties' pop-up window.
Graham
By Tim Dawson - 3/11/2013 5:51:31 PM
It's possible that one day we might implement a "radio services" map view showing coverage, but in the meantime, this is what the Nearby ATS screen is for in flight. It instantly tells you who you can talk to, include the appropriate FIS frequency for your current position and altitude.
