Top of Descent and V/S
http://forums.skydemon.aero/Topic8288.aspx
By knorren - 1/29/2013 10:58:58 AM
Hello!
I miss some small things in the SD and that is it would be great if the TOD-point would be visible on the "normal" navigation display.
As i understand that TOD-point is only visible in the height profile display and it would be greaat to have also on the normal map Smile
Another feature I would love to have is that if you could set your own preferred Vertical Speed (V/S) much easier than today. Now you must go into the Aircraft profile and edit that but even if I use the same aircraft I often want to use different V/S for different legs or heights when flying a route. Sometimes I want 500 fpm and sometimes I want more/less. I depends on the situation, traffic and surroundings.
So for example you may be able to adjust your preferred V/S in the Leg Proporties dialogue box Smile
And another feature would be that maybe you could use the HSI (or similar) and give you guidance directions also in vertical navigation so that you will arrive at the next desired altitude where you have planned for it Smile
By ckurz7000 - 9/12/2013 11:17:21 AM
Personally, having the TOC/TOD marked on the map is overkill for me. Having this information displayed on the vertical cross section is entirely sufficient (for me). Leaving the main map area as uncluttered as possible wins out in my case.
