METAR TAF disappeared....
http://forums.skydemon.aero/Topic7701.aspx
By IstvanToth - 10/31/2012 12:16:44 PM
Hi, I'm relatively new to this program, I bought it about 2 months ago for my iPAD3 (OS-5), made 1 further update, and downloaded today the last version of it.
Since I loaded once a flight-plan which I created about 2 months ago, all the plans, as the older as the new ones are without the possibility to read the METAR nor the TAF.
Any idea what I may do wrong???
PS: wish for the programmers: I need the possibility to block the UNDO command or have at least a REDO option. If you hit by accident the UNDO you just don't know where or what was canceled.
By IstvanToth - 10/31/2012 5:45:49 PM
Meanwhile I found the solution by my self in the troubleshooting section. The answer is here:
Why can't I see NOTAMs, TAF or METAR?
SkyDemon relies on an internet connection for certain features such as NOTAM and weather briefing, AIP and AFE airfield plates and flightplan submission. If you cannot access these features it may be the case that you do not currently have a stable internet connection or you are working in Offline Mode. Tap Setup then Communication Options on your iPad, or click the Route button on the toolbar in SkyDemon Plan on your PC to ensure that Offline Mode is not ticked.
