Post Code Function does not seem to be working
http://forums.skydemon.aero/Topic7602.aspx
By CWJ - 10/23/2012 10:07:45 AM
In latest version downloaded yesterday to replace previous one, I also downloaded the postcodes zip file, extracting it to the same folder as the sky demon program files.
I had understood from the brief instructions with the download section of the website, that typing a postcode into the "Find" box was all that was required. Nothing happens. I have treid with both a space in the UK post code, and without one.
By Tim Dawson - 10/30/2012 10:32:37 AM
There is a brief section covering transfering things to the iPad including the postcode database in the documentation, below:
http://www.skydemon.aero/plan/documentation/ipaddata.htm
However please be aware that in the 2.4.4 version of SkyDemon for iPad (2.4.5 is still not quite out) you may encounter a bug where you cannot select the search results after a postcode search.
