iPad wind readout
http://forums.skydemon.aero/Topic7369.aspx
By 2greens1red - 10/1/2012 9:26:35 AM
I'm sure this has been answered elsewhere, but I was trying to figure out, when in flight, what the wind field should show (under the vertical column of GS, Track, Alt. etc.) - at the moment all I have is an X (for no data?).
In simulation mode it shows a wind - is it a random figure?
Also, is there an SD/iPad manual available?
Many thanks.
By Tim Dawson - 10/5/2012 4:45:52 PM
If you specify a takeoff time for your flight, SkyDemon will make sure it has all forecast information available in that time window. If you don't set a takeoff time, it'll assume you're taking off in the near future.
