Dragging map on iPad
http://forums.skydemon.aero/Topic6608.aspx
By MrReallySerious - 7/18/2012 1:54:52 PM
It seems to me that dragging the map around is more sensitive then for example Google Maps. Is it possible to make the map dragging a little less sensitive? Sometimes a little flick will move the chart to further then intended. My experience at least is less optimal, compared to the behaviour of Google Maps.
edit: it esspecially noticable when zoomed further in. alsothe map moves much further when you flick faster.
By Denis - 9/2/2012 4:54:53 PM
I believe IPad was designed to work this way with a fluid movement and was not intended to be used with a flick action unless you require it to move a larger area or a full page at a time, I like the way SD works on the IPad and I think it's brilliant, if this feature was changed it would need to be adjustable so that we could keep the original setting for those who like it.
I don't know whether you have noticed or not but using Google through SD (as in view on map) appears to reload much faster than through Google itself.
