Colin Bond (22/06/2012)
One thing I noticed (unless I missed a trick) is that although the position of the postcode is shown as a 'cross' on the map, you can not directly insert it as a waypoint. You can note the lat & long given in the "Find" box, and then create a user-defined waypoint as normal. Maybe a tweak in the future could make this process automatic, if required by the user?
Just right-click on the centre of the 'cross' and select "Create User Waypoint" from the pop-up menu.
