By m046238 - 5/1/2017 8:28:35 AM
+xThank you, we will update our chart. Bonjour,
Please, could you check again ?
Thank you
daniel
By Tim Dawson - 5/2/2017 12:19:45 PM
Check what? If you believe any VRPs are missing, or we have some we shouldn't, the best thing is to state them explicitly.
By m046238 - 5/3/2017 4:06:16 AM
+xCheck what? If you believe any VRPs are missing, or we have some we shouldn't, the best thing is to state them explicitly. According French SIA answer above this subject, (2 May 2017). The answer at your question is available in current French AIP of ENRoute section 1.2 page 24 (REV 30 MAR 2017) available in current SkyDemon APP.
French SIA answer (in French) attached for clarification.
Kind regard...
Suite à la fermeture de la base aérienne, Dijon –LFSD est devenu un aérodrome uniquement civil à la fin de l’année 2015. La CTR a été supprimée et le terrain est géré par un AFIS. Tous les documents gérés auparavant par les militaires (DIRCAM) ont été transférés au SIA pour les publications. Les itinéraires de transit CTR ont été conservés en tant que Itinéraires de transit en Région Dijon et apparaissent dans l’AIP en ENR 1.2 (page 24 du fichier PDF). Le SIA va demander au gestionnaire de l’AD LFSD s’il ne serait pas judicieux de republier une carte « transit » faisant apparaître ces itinéraires dans le VAC.
Cordialement.
By aeroecho - 6/4/2012 10:40:18 PM
While preparing a navigation, I realized that some VRP are missing for the transit in the Dijon CTR (LFSD). I refer in particular to N, NA, NB, NC, SA, SC, SR (that you can easily find on the "AIP transit VFR chart" available inside SkyDemon since today ;-).
Thanks for their addition in the next charts release.
Kind regards, Julien
By Tim Dawson - 5/3/2017 10:27:41 AM
Ok, my French skills are not very good so I pushed that through an online translator and I think I understand.
What I don't understand is if you're suggesting there is something wrong in our charts?
By m046238 - 5/3/2017 2:41:04 PM
+xOk, my French skills are not very good so I pushed that through an online translator and I think I understand. What I don't understand is if you're suggesting there is something wrong in our charts? That is right, in SkyDemon map N, NA, NB, E, SA, SB, W VRPs are missing and VFR Transit North-South - 1700' AMSL (N-NB-E-SB) VFR Transit North - 2500' AMSL (NA-NB) VFR Transit South 1700' AMSL (SA-SB) VFR Transit West 1700' AMSL (SA-W) According French AIP ENR 1.2 page 24 PDF document and FRANCE NORD-EST 1/500 000 IGN map and AirNavigation Pro.
French SIA "suggests" at LFSD administration to update VAC plates according this to clarify.the situation.
Merci de votre compréhension.
By Tim Dawson - 5/4/2017 8:47:46 AM
Ok. Since there are no VRPs listed on the official VAC for LFSD we will need to wait until they are added by the SIA, then they will be in the official digital data which we use.
