Weather and NOTAMs again :/
http://forums.skydemon.aero/Topic5845.aspx
By madgav - 5/7/2012 4:21:06 PM
I'm playing with the evaluation version of SD Plan and have entered several test routes but have noticed the following problems:
• 'Messages' window filling up with messages such as "Corrupt data detected while interpreting downloaded forecast wind information" and "Corrupt data detected while interpreting downloaded NOTAM information"
• 'NOTAM' window has some NOTAMS but also error messages such as "The latest available NOTAM data for the Scottish/Shannon FIR is xx hrs/mins out of date". How can I be sure I am getting all of the relevant NOTAMS? :/
• 'Weather' window has never functioned, only a message appears "Weather forecast info will be retrieved when a route is plotted".
• TAF and METAR data appears correctly in the relevant windows, but weather symbology display on the chart is erratic, sometime it works, sometimes it doesn't.
I've read the post below on a similar problem on ipad and have tried (i) setting flight time and (ii) restarting the app, neither of which have solved the problem.
I am on a PC not an ipad.
Also, is there any way to manually "refresh" data?
Gav.
By Tim Dawson - 5/18/2012 3:21:57 PM
No, that's the address of the SkyDemon server and the only other computer SkyDemon talks to.
