Ability to Add more Airfields to area NOTAM data
http://forums.skydemon.aero/Topic5247.aspx
By rotorpig - 3/10/2012 8:33:31 AM
Just started using a trial version, and impressed with the product so far. I need to fly within a defined local area which is easy to set up in Skydemon. However I need to have NOTAM data for all airfields within this area, more than departure, destination and alternate currently allowed in Skydemon. I currently use the NATS website and this allows a selection of numerous airfields to be used and saved and all NOTAM data. Adding this multiple airfield option to the area briefing would really be usefull, perhaps a worthwhile addition to the route facility to?
By pink leader - 3/10/2012 8:32:35 PM
One thing you can do is set up a circualr route around your home airfield taking in the area you require. You can save this and reload whenever you want.
As soon as you load it, the NOTAMs, TAFs & METARs will be downloaded from the web and display on screen (as long as you have the display function set).
D
