SkyDemon Beta version posted 19th Jan 2012
http://forums.skydemon.aero/Topic4729.aspx
By srayne - 1/20/2012 11:59:10 AM
When running the GPS simulator and I select the new High Contrast Charts then there is a "method not supported" exception.
Details as follows:
System.NotSupportedException: Specified method is not supported.
at Divelements.SkyDemon.Mapping.MappingOptions.x54519162d2621a44(ChartStyle xdc050473bf022183)
at Divelements.Aviation.UI.x8974cd36e3a1aa90.xb9baf3df21c3cc77(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at Divelements.Aviation.x0092af0fd5f60683.OnActivate(EventArgs e)
at Divelements.Aviation.x0092af0fd5f60683.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.ControlNativewindow.OnMessage(Message& m)
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4216 (VistaSP2GDR.050727-4200)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SkyDemon
Assembly Version: 2.2.1.18968
Win32 Version:
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SkyDemon.exe
Divelements.SandGrid
Assembly Version: 2.2.4.1
Win32 Version: 2.2.4.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.SandGrid.DLL
Win32 Version: 2.0.50727.4214 (VistaSP2GDR.050727-4200)
System
Win32 Version: 2.0.50727.4215 (VistaSP2GDR.050727-4200)
System.Drawing
Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
SandDock
Assembly Version: 3.0.6.1
Win32 Version: 3.0.6.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandDock.DLL
Assembly Version: 1.0.4401.18966
Win32 Version: 1.0.4401.18966
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Aviation.DLL
Divelements.Mapping
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/Divelements.Mapping.DLL
System.Xml
SandBar
Assembly Version: 1.4.3.1
Win32 Version: 1.4.3.1
CodeBase: file:///C:/Program%20Files/Divelements%20Limited/SkyDemon/SandBar.DLL
By Tim Dawson - 1/20/2012 5:52:51 PM
Thanks Simon. The fuel problem is because we're halfway through implementing a new feature whereby fuel measurement type is specified per aircraft, not generally in the software. You're seeing a problem because we haven't exposed the setting to change it in the current beta and your aircraft profile will need to be updated. We'll get this into the next beta and would appreciate you testing it out, especially if you fly different aircraft each with different fuel units!
