Clock
http://forums.skydemon.aero/Topic4672.aspx
By pink leader - 1/9/2012 12:30:18 PM
Just noticed that SD Mobile time display is not (or does not seem to be) controlled by the GPS satellite time feed but by the internal device clock. If that clock is wrong then ETA etc is also wrong. What it does seem to do is correct such time for Zulu.
Not a big deal to change device clock manually but would it not be better to use a precise time feed? Better still is there aWinCE setting that updates the internal clock whenever a GPS feed appears.
Again, not sure I am right about this but I think igo8 uses the satellite time in its ETA calculations and so it should be possible.
D
By Tim Dawson - 1/12/2012 4:31:17 PM
SkyDemon resets the device clock if the device clock does not agree with GPS time.
You still need to ensure the timezone is set correctly in the device settings if you want SkyDemon to reliably convert such times to "local" time.
