SkyDemon softwear problem
http://forums.skydemon.aero/Topic4670.aspx
By Quantas - 1/8/2012 8:24:19 PM
Hi
I have a problem, when I try to open Skydemon I get ,"SkyDemon.exe has encountered a problem and needs to close" I have rebooted to computer deleted the program reinstalled it and it still will not let me in. Has anyone else had the same problem? Someone please help.
By filippo1974 - 1/12/2012 12:07:16 PM
paulmoodie (11/01/2012)
I'm not to sue what the .NET FRAMEWORK is
The .NET Framework is a set of software libraries and components that are required to run certain software applications, such as SkyDemon. There are different versions of this framework. Most software products that rely on the .NET Framework need at least version 2.0 of this framework. Different versions of .NET Framework can co-exist in the same PC without problems.
Normally, the .NET Framework can be installed directly from within Windows Update. Newer Windows versions (such as Vista and 7) have it installed by default. This is not the case with Windows XP, and therefore it is necessary to explicitly install it through Windows Update as I said before, or downloading the setup package directly from the MS Download Center web site.
Anyway, glad to know You managed to make SkyDemon run.
Best regards,
Filippo
