Shroud for Skydemon GPS
http://forums.skydemon.aero/Topic4619.aspx
By Martin B - 1/2/2012 6:38:53 PM
Hi Folks, I'm new to the forum and used my Skydemon GPS for the first time in my Gyrocopter today.  I found it very difficult to read in bright sunlight and was wondering if anyone else had this problem and how they have overcome it.  My gyro is an open cockpit but I was wondering if some sort of shroud over the top and sides would ensure that I could read it. Has anyone got any bright (excuse the pun) ideas?
Martin
By nahh! - 1/8/2012 6:29:48 PM
I use Skydemon on a cheap Chinese 7" GPS in a Jodel - a lot of canopy and a lot of light. What I did was to put two velcro tabs on the gps top corners. These tabs match up to two velcro tabs on the underside of rectangular 1lt ice cream tub (Kelly's Cornish Clotted Ice Cream - sure other brands will work just as well Smile) which I've cut out to match the the screen size.
It works pretty well and the shield is quickly removable in flight.
I've also seen suggestions about removing the thin plastic sheet from the screen - not yet tried that but it would be quick to do
