Fuel and weight/balance not updating automatically
http://forums.skydemon.aero/Topic4575.aspx
By rcrocker - 12/28/2011 1:52:46 PM
I have just got a Skydemon GPS as an Xmas present and think its great.  However there is something that I have found that I am not sure if I am causing an error as I am new user or if there is a program feature that I don't understand.
The documentation says about weight and balance:
"All the values apart from Fuel need to be entered manually. The Fuel value can also be adjusted manually if you wish, but it will be overwritten when the fuel plan is next updated."
However I prepared for flights where a full tank of fuel and passengers has put me over weight.  The weight/balance window has flagged up red, so I have gone back to the flight details window and reduced the fuel load using the slider.
However when I look at the weight/balance window, the fuel weight has not reduced to reflect the change I have made to the fuel plan.  It still appears to show a full load of fuel weight.  i.e. the fuel plan update does not seem to adjust the fuel weight automatically when it is changed.
The only solution I have found is to manually calculate the reduced fuel weight and manually re-enter it into the weight/balance window to get my weight/balance window to show the correct fuel weight and confirm I am within limits.
Can anyone advise if I am missing something ?
By Tim Dawson - 5/16/2016 3:03:50 PM
Whatever the problem is, it's not going to be the one this thread was started for 5 years ago. It might be best to give support a call, as there are any number of factors involved with weight and balance issues.
