Printed Pilot Log suggestions
http://forums.skydemon.aero/Topic4382.aspx
By Alexey - 11/9/2011 9:33:29 AM
1) Suggest to have more flexibility to select which columns to be printed on the plog.
I put plog on my lapboard format A5 portrait. In this format text and numbers become too small. Sometimes I am willing to eliminate some columns in order to free up space for what is left. I understand that some columns are calculated based on other columns, and I do not propose to change calculation logic, simply add show/hide column switches for all columns.
2) Add empty "Notes" column (again switchable) to have some space on each line for some extra hand writing.
3) Put "fuel" column to the extreme right position in order to move "ETA" "ATA" and "Notes" to the left away from the right edge of the paper. ETA and ATA is most likely to be filled by hand during flight and writing on the right edge is not convenient.
4) If technically possible, have system to remember page setup (size and orientation) individually for each document, ex. PLOG - A5 portrait, Charts - A4 Landscape, etc.
By steinardo - 11/9/2011 10:19:21 AM
I second this.
