2.2 Beta High Contrast Maps
http://forums.skydemon.aero/Topic4342.aspx
By Dan P - 11/1/2011 6:38:27 PM
Hi Tim & Team,
Thought I would be the first to comment on the high contrast mapping.
Have been using for planning and also 3 flights on Saturday and must say I find the maps brilliant, also the display in bright sunshine is far clearer.
I know you have said these will not be implemented in the next release but I am not looking forward to going back to the old ones so my preference would be to at least have these as an option to complement the existing choices.
Also on the last couple of flights for some reason I seem to be losing GPS lock the screen displays 14 in view 14 found but no aircraft symbol and cross in the virtual radar screen. The only way to restore is to reboot and start again. There used to be an option tick box to say require precise fix or similar which has been removed which I used to have ticked
Dan
By stevelup - 11/6/2011 6:24:33 PM
The checkerboard pattern disappears after the device has rendered the terrain. On a slow device, this can take a minute or two, but it only has to do it once per zoom setting.
I used the high contrast scheme today and it was excellent. I hope it makes it into the next release.
