Custom data
http://forums.skydemon.aero/Topic4335.aspx
By steinardo - 10/31/2011 8:27:06 PM
Bug 1: If you don't add a leading zero to runways below 10, the runway direction is not shown on map. Suggest to automatically add this.
Bug/suggestion: If you add two runway identifiers that don't "add up", e.g. 05/33, then 05/23 is shown on the map. Suggest that some error correction is added here. One solution could be that when you add the first runway identifier, then the other is automatically suggested for the other identifier (+/- 18) at the far end. Unless there exist runways that only are used one direction... or are curved...?
By Tim Dawson - 11/1/2011 12:38:50 PM
Not that I know of, but there are runways with only one end. At present we don't intend to add additional logic to the data creator app for this purpose; it's supposed to be a tool for advanced users and doesn't receive quite the same level of user-friendliness or foolproofing that the main software does. We will consider it in the future though if it rises to the top of our priority list.
