Why no option to route direct to a random point on map?
http://forums.skydemon.aero/Topic4021.aspx
By shawkins0 - 9/8/2011 1:20:24 PM
If I use the map to select a VRP or a Navaid I get the option of 'Route Direct'.  If I press on a random part of the map, the lat/long comes up and I only get the option of 'Append to Route'.  Why don't I also get the option of 'Route Direct'?  This would seem like an easy fix.
On a separate issue, when I select 'Flight' and then 'Direct To...' why am I limited to only typing in airport names?  Why can't I type in a Navaid or VRP here?
Thanks.
By Vref - 9/9/2011 4:05:38 PM
On the AV80R I used to fly with a lot and also in some way the GNS430 (nearest AD's. Navaids waypoints etc..) give you the option Direct To--> Airport or (VRP)waypoint or navaid..etc..As such you still can select what you want. Only having the aerodromes is important but not everything..
