Direct to - Give this a go to see if it's what you want, there are three ways1. When in chart view with a GPS signal, hold your finger over the airfield or waypoint of choice, it will then show the name of the airfield or waypoint (including the waypoints you put on the chart yourself) If you tap the name you will get more options e.g. Start route here, View Plate, or Route direct.
2. Tap the blue SD logo at the top left of screen, Now tap 'Flight' and you will see in the list 'Direct to'
3. Probably the easiest of all, with the Virtual radar displayed at the bottom of your screen, use either your finger or stylus to swipe it accross the bottom of the screen from left to right and you will be presented with the 'direct to' menu
Hope this helps good luck
