Flight Plan Equipment Codes
http://forums.skydemon.aero/Topic3926.aspx
By Keef - 8/30/2011 1:01:30 AM
I've finally got round to looking at SkyDemon (I wasn't in a rush because I've been using NavBox ProPlan for years and know how to drive it). Thus far, I'm very impressed.
I looked at the Flight Plan submission module - which I probably wouldn't use, since I do my own with AFPEx - and noticed that it had indigestion with the equipment of the Arrow I fly. That has full airways kit including VOR, ILS, DME, ADF, Markers, GPS with BRNAV certification, 8.33kHz VHF/RT, and Mode S with basic surveillance.
I think the correct coding for that is SDGRY/S but SkyDemon came up with a much longer string, identifying each item separately rather than using the "S" for "Standard". It didn't do the BRNAV or 8.33kHz.
Not that I mind, and not that it's likely to matter for many users, but for the sake of completeness...
Now back to learning how SkyDemon works.
By Tim Dawson - 8/30/2011 5:33:49 PM
You're right, SkyDemon currently only replaces the FLOV with S under certain conditions. We'll make it a little more clever in the next release, though either way should be valid.
