Trace Log
http://forums.skydemon.aero/Topic39117.aspx
By giannisd - 8/25/2026 3:19:03 PM
I like the Trace Log, but when I evaluate my fly on the radar I use the finger to move it along the trace but if I stop the follow it go back on the top sky and do not stay on the trace , is possible that the aircraft remain on the trace to the position if I interrupt the moving ?
By GalaxyzA11+ - 9/7/2026 7:31:03 PM
In between,
Note that once you grab and hold the plane,  you may slide the "finger downwards" and then right or left.
You don't need to keep the finger over the line , which is usefull to read the informations at the plane current position.
HtH.
