Standard route segments
http://forums.skydemon.aero/Topic39066.aspx
By matthew_w100 - 7/1/2026 1:13:57 PM
Would it be possible to allow a "standard route segment" to be added to a planned route?
Flying out of Redhill I have a very limited number of departure options, which can be quite complex due to the surrounding airspace.  For example if going north I have to route via Ascot & Burnham through the Heathrow Class D or through Farnborough.  West, it's Solent.  East it's Luton or Southend. My standard segments can have up to a dozen waypoints, and more importantly, different altitudes on each leg to maintain.  It would be very useful to be able to set these routes up as standard segments which I could add to the start (or end) of a planned route. Others may find a frequent segment in the middle of flights, like (what used to be called) the Manchester LLC.
It would be great to not have to type them in afresh each time. And to be able to share them with others.
Thanks for your consideration!
By matthew_w100 - 7/6/2026 6:39:54 AM
grahamb - 7/1/2026 9:27:37 PM
Why not just save each one as a route in its own right, and start each new route by opening one of them, then extending it as required?
Well that would work in the simple cases like the ones I suggested, but it's not got quite the utility of being able to stitch segments together.as a more general facility.
