Selecting options from menus
http://forums.skydemon.aero/Topic38713.aspx
By tnowak - 2/19/2026 4:25:09 AM
I use a small screen smartphone for SD navigation.
When I want to, for example, select "Go To" it is sometimes a challenge to "hit" the correct option when it is a bumpy flying day.
Would the SD team consider making the "while flying" menu options a bit larger, a bit like the selection of airfields to choose from, when you do get to that option?
Perhaps larger "rectangles" to aim ones finger at, rather than a thin line of text.
Maybe also look at all the SD "settings" options to see if the layout can be improved?
By Tim Dawson - 2/25/2026 9:40:52 AM
Thanks Tony. The Direct To items are forced bigger to accommodate their graphical content. The "regular" menu items should be the same height as (for example) the items under the Route or Settings menus, which (on a phone) should be at least 7mm high, or higher depending on the font size on your device.
I would feel uncomfortable unilaterally increasing this height as it's been the same for many years, with a great deal of people accustomed to using it. However, that particular menu is ripe for an overhaul, which may happen this year, at which point its layout will probably change anyway.
