Merge Logs function - can no longer find it
http://forums.skydemon.aero/Topic38507.aspx
By Gaznel - 11/10/2025 9:51:23 AM
I can no longer find the Merge Logs button. I used to click LOGS - [Recent Flights] - [Select Flight] and near the bottom was the Merge button. Alternatively going [LOGS] - [ALL MY LOGS] - [Select Flight] - to get to the same screen as above. Now the screen I end up with is pasted below and the MERGE button is not showing and nothing to scroll down on that page. The EDIT button on the below page just takes me to edit Aircraft of Simulated  - any idea where the merge function is?
By Tim Dawson - 6/29/2026 9:10:04 AM
If your log is Mergable, you'll see a Merge button when you look at it.
