By norland - 11/4/2025 9:20:03 PM
If you press what’s here anywhere there is airspace, you get the nice graphical vertical presentation of elevation and airspace, so as well as showing you airspace a quick press of what’s here gives you the ground elevation in a nice format.
However when flying in a Class G area with no other airspace, the vertical graph is not shown, and to get the elevation requires another fiddly press on the location which does give the ground elevation amongst the info.
Personally I’d prefer if the vertical graph was always in what’s here, to show ground elevation , even if there is no airspace. Can’t see any downside?
By norland - 1/13/2026 4:51:04 PM
Good to see this appearing in the latest release!👍
