Flightplan feature request
http://forums.skydemon.aero/Topic38347.aspx
By moefly - 9/5/2025 10:42:52 AM
I love the built-in flightplan feature in Skydemon.
Many countries in the southern / eastern part of Europe like to see "ULAC" in the aircraft type designator field for Ultralight aircraft and the actual type as part of the Remarks, for example: ULAC TYPE TL30 or in Italy: ULAC ADVANCED TYPE TL30 (to distinct between basico and advancato ULs there).
In addition to that and as discussed in other threads we shall now add "BRS" in the remarks field in for planes having a ballistic rescue system installed.
While ULAC can be easily put into the aircraft profile, I have to add the other strings manually in the flightplan filing process in Skydemon.
Would it therefore be possible to get this functionality added so I can select a UL type airplane in the profile with the according ICAO type and Skydemon automatically sets ULAC as the designator and the ULAC TYPE XY and BRS into the remarks?
Another related question I have:
Would it be possible to add a feature to activate a flight plan from within Skydemon?
At least the german DFS has such a functionality if you use their website for the flightplan mgmt, so I was curious if that is sth that would be doable in SD directly as well.
Thx in advance!
By Tim Dawson - 9/8/2025 9:45:25 AM
Would you like me to move this to the Suggestions forum so others can contribute?
