ok, thanks. The thing with typing in FL levels works as you said.
And yes, all of this stuff can be worked around, but having SD match up with cockpit instruments would reduce the risk of a mistake.
From a planning perspective, on low pressure days the base of airspace can be brought down to point where it's interacting with areas below it limited by altitude. I'll put something in the suggestions forum.
