Connect Garmin G3x with bluetooth module
http://forums.skydemon.aero/Topic37950.aspx
By Jseb - 3/23/2025 10:23:42 AM
Hi, I want to use new feature with bluetooth with Garmin G3x autopilot.
I'm interested to use autopilot from Skydemon GPS and route.
I did it on a Trio autopilot, it work well, but no idea if it's possible with Garmin.
By Anthony VL3 - 4/19/2025 5:39:01 PM
vikino - 3/23/2025 10:51:54 AM
Hi, it is tested and working with G5 and Garmin AP, there can be problem if you feed AP from G3x, but if you dont enagage AP on G3x and feed it from BT-RS232,should work
Can you tell me the wiring you did? And the programming in the Garmin?
Thanks Smile
