I fly a number of aircraft with different Reg numbers. Usually, if the Reg number does not accord with the information in SkyEcho 2, a message would pop up saying that the planned aircraft is different and should the Reg be changed. This no longer happens. If I go to the SE2 Configuration tab in Sky Demon I get the following error message: " Failed to get settings from the device. An invalid response was received from the device". Other than this error the iPad still connects to the SE2 and operates normally. I am running SD on an iPad mini 5 with the latest update (18.3.1) and the Sky Demon software is also the latest release. I get the same problem using a different SE2... but there is no problem if I use my SE2 with my iPhone or different iPad. The issue must be with the SD installation on the iPad mini. I have deleted and reinstalled the SD software but it has made no difference. I have now run out of ideas! Can anyone help? Thanks.
EG
