Hi I try to get Autopilot over BLE to work i can make connection and see data when connect the modul to a PC with a FTDI cable, but i only get the first 20 char of the data.
SETUP:
iPad pro 11"
BT05 BLE modul and level converter TTL to RS232 when connect to the autopilot.
I read some where that there is some limitation on the serial connection over BLE at 20 char, can this be the problem?
I have made the same BLE setup to the radio and it work :-)
