+xThey are logs of your flight, that doesn't mean we are going to log every single input from your GPS.
At present (this could change) we log a position every 5 seconds, unless there is a significant change in your track or speed or altitude, at which point we log extra snapshots.
Hello Tim,
thank you for your quick answer.
I just thought if I use this data for overlays for a video it is maybe better to have data points every second - at least it looks better when I compare videos made with the SkyDemon data with videos made with data from my garmin fenix watch (which is set to a frequency of 1 Hz to collect data points) - especially the heading turns smoother. For all other data one position every 5 seconds seems to be good enough.
Unfortunately the height information is worse with the fenix data - when landing at the same airport where I took off I am often about 10-15 m higher :-(. With the DUAL GPS receiver it is more accurate.
But your answer makes reason - for at least 99.9% of the users and applications this is good enough.
Thank you again for your answer and for the well-made software with all its great improvements over time - I enjoy every second with your software including planning and flying :-)! I appreciate all of your work and effort.
Best regards
Mark
P.S. Maybe I will be at the aero Friedrichshafen this year - then I could come by to see you personally.
