When hovering over stacked pieces of airspaces, on the left it shows the vertical cut as normal with the ground at the bottom, but on the right they are listed with the lowest airspace at the top and then listed downwards.
Spontaneousy it would feel more practical to have both vertical cut and description aligned at the bottom and then going upwards.
Have you prototyped this already maybe? Could we have the option of either order?
