Weather time slider removed from 3.16.4
http://forums.skydemon.aero/Topic35626.aspx
By Alans7 - 10/25/2022 7:56:28 AM
Time slider has been removed from 3.16.4 and replaced with Animation, which is not as usable because you cannot pick a time and study the forecast weather along your route or over a whole region. You also cannot adjust the step speed of the animation.
Please bring back the Time Slider, or add manual buttons in to the animation pop up box, so that we can manually step the time backwards and forwards.
By Tim Dawson - 10/28/2022 9:34:48 AM
You can slide the time to whatever time you like, by pausing the animation and then moving your finger left and right where the time is displayed. You can also move your finger up and down to change the altitude at which wind is being depicted.
