The User guide gives us the format for ICAO code airfield pdf imports ....."To add one of your own PDFs to the list for a specific airfield, just make sure that the PDF’s filename
begins with the airfield ICAO code or local identifier followed by an underscore, for example
EGBK_filename.pdf, and the document will then be available alongside the other official plates when
you open the Airfields tab and tap on the airfield in question."
Anyone been able to get pdf's imported to the specific airfield when that airfield just has a name (no local identifier) in SD? I can get them into the user docs but not associated with the actual airfield.
