Distance to threshold on HSI/ILS
http://forums.skydemon.aero/Topic35060.aspx
By WiltshireMike - 5/25/2022 10:06:48 AM
The pull-up HSI / Glidepath is really helpful but would it be possible to add the 'Dist Thr' value plus 'target vertical speed' (which appears momentarily after selecting 'make approach') onto two of the 'empty' quadrants of the HSI indicator itself when in 'pull-out' mode?
This would help by putting all the approach info into one place and also take advantage of text re-sizing when expanding the HSI pull-out.
