Scratchpad
http://forums.skydemon.aero/Topic34846.aspx
By RK - 4/9/2022 7:38:05 AM
I am FI and would like to take notes on the scratchpad during the flight.
These should of course still be available for debriefing after closing Skydemon. However, saving the data would be necessary for this.
By Sky Painter - 4/11/2022 11:25:06 AM
There is an Android app called Simpleaf (probably also available for iOS). If setup properly, it can be opened at any time by dragging down on the notification bar and it overlays the SD chart. It can also be setup to open in translucent mode so that you can still see the chart. The app also has a button which, when tapped, cycles between translucent and opaque modes. You can make notes across multiple pages which are saved, even after closing the app, until you decide to delete them.
