Hi
Not sure whether the geometry of the CTR for FAOR is the challenge, but have picked up that the eastern side of the CTR is not correct.
The FAOR CTR should encompass the FAGM ATZ, however it is depicted as a straight line disecting the ATZ:
The AIP describes the CTR as:
The area bounded by lines drawn as follows, excluding the Rand ATZ.
a. From a point at S260002 E0282344 a straight line joining the FLW points: S261632 E0282014, S262232 E0281429,
S262332 E0281139, S261602 E0280439.
b. Thence clockwise along the Rand ATZ to a point at S261117 E0280559.
c. Thence a straight line joining the following points S255902 E280959, S255222 E0280629.
d. Thence anticlockwise along the arc of a circle, radius 7 NM and centred on a point at S254931 E0281347, to a point at S255632 E0281139.
e.Thence a straight line to the starting point
Point (b) above is the one that is incorrectly being interpreted on the SkyDemon chart.
Andrew
