+x+xIt's very straightforward in flight to either reroute your plan around some airspace, or (as someone else said) to take a shortcut through the airspace if you've originally planned around it.
Not straightforward in my set up. I'm flying in an open cockpit with skydemon on a 6 inch phone screen. I can just about cope with a one touch plan b solution which might be the take short cut feature if I could find it. Advice please.
As an aside I dicussed with others the desirebility of plan b and noone mentioned the short cut possibility which is perhaps not widely appreciated
Press on the turning point you want to shortcut to, touch the waypoint name in the popup, and touch ‘Take Shortcut’ in the next popup.
Alternatively, bring up the PLOG by touching the Nav Text at the top of the chart, touch the waypoint you want to route to and select ‘Take Shortcut’ and close the PLOG.
Try it in simulation mode and see which you prefer.
