Czech Republic (LKAA) AUP not correctly desplayed
http://forums.skydemon.aero/Topic33369.aspx
By 177 - 5/2/2021 3:18:28 PM
Tim Dawson - 4/30/2021 9:31:44 AM
Thank you for the feedback. We are aware of this issue, and have been discussing it with Czech authorities. Unfortunately at the moment they do not publish all AUP data into the Eurocontrol AUP tools, which is where our Europe-wide AUP data comes from.
I can see that your example today of TRA31 fits our understanding perfectly.
I will raise the issue with them again. It is an unsatisfactory situation because we do not wish to remove all AUP data for Czechia from SkyDemon, but we may need to do that if a resolution is not found for the issue.
Thanks! Let us know how it's going
By Tim Dawson - 5/4/2021 10:21:21 AM
After some discussion with Czech AIS, lots more areas will be lighting up in SkyDemon later today.
They currently are not able to provide AUP data via SkyDemon for RSAs with upper limits lower than 5000 feet (they've listed them below) but they also say that they will be able to publish this data in the near future (months).
TSA20, 21, 22, 24, 26, 27
TSA60
TRA10
TRA61
TRA17
TRA71
TRA72
TRA73
By 177 - 5/4/2021 12:02:03 PM
TSA60
TRA10
TRA61
TRA17
TRA71
TRA72
TRA73
By Quit - 4/29/2021 9:54:57 PM
Since version 3.14.5 from 26 OCT 2020, AUP active areas should be displayed on map when planning route and during flight. Especially for Czech republic AUP data are not loaded/displayed correctly.
Here is example from 30 APR 2021 - Area TRA31 will be active from 7:00 till 12:00 from 1000AGL to FL245 but in SkyDemon this area is not shaded even when route is planned through this area with departure set 30 OCT for 7:30 with cruising altitude 3500ft (SkyDemon screenshot). Same problem is for TRA32 & TRA33.
It is interesting that some other areas (e.g. TRA3) has been correctly shaded and displayed time of activation.
(Filters for airspace objects are set for week view from GND up to FL95)
By Tim Dawson - 2/2/2022 2:34:06 PM
Czechia have now updated their system so that all areas are now activated correctly by AUP in systems like SkyDemon.
