"That's down to your SkyEcho 2 configuration. Perhaps it's worth reading the manual for that product?
I have read the SkyEcho2 manual and configured SkyEcho2 correctly.
My issue is / was with SkyDemon and the way it displays aircraft when using SkyEcho. More specifically trying to debug an issue.
The SkyDemon manual I have read too. It doesn't say that the details of the aircraft being used in SkyDemon must explicitly match those of the SykEcho. Yes you get a warning message when you "Go Flying", but several users I know have just ignored the warning for a couple of reasons:
- In SkyDemon they had not set a Hex code. This is because they had never needed to set a Hex code. Therefore it was left empty / unset. This is what happened to me too.
- Then when they got the warning they couldn't figured out what the issue was. This was my case too. I had my Hex code in SkyDemon empty and hadn't realised that this needed to be set.
- The next thing that compounded the issue was changing the Hex code on one SkyDemon device (for example iPhone) and not explicitly syncing the aircraft with the cloud after making the change. This meant when they used another device (for example iPad) for flying the Hex code was not updated in the aircraft setting being used. They needed to get the aircraft again from the cloud.
I'm putting the above info on this post as if it can happen to 5 or 6 different users that I know, it might help others who are also experiencing the same issues.
Cheers,
Chris
