Flightplan: “Type of flight” choice (G vs X)
http://forums.skydemon.aero/Topic32926.aspx
By KiloJuliett - 5/20/2021 3:22:21 PM
I can confirm that some airports require "X" as flight type for training lessons. It is the case for my homebase LSZH (Zurich). Also, I'm required to file a flight plan for any flight to/from LSZH. But I currently cannot comply with the requirements for a training flight when using the Android App. I would therefore much appreciate if the flight type option can also be made available there.
By Dema - 2/27/2021 4:32:49 PM
In the flightplan, in field 8 (Type of flight), it would be great to have the possibility to select between G (default for General aviation) and X.
X is often used from many of us when you have a Training Flight, a school flight, an exam flight.
In many airports this info let you pay less for the landing fees.
If we will have the opportunity to specify X, than we can indicate manually in field 17 (for example): RMK/TRAINING FLIGHT in combination with X in type of flight.
Thanks for evaluating it. 👍😏
Ciao
Andrea
