Hello gents,
I was planning some low level IFR flights in Spain and found some issues with the depiction of airspace around some airways.
In Spain, all airways are controlled airspace, at least Class D for low level and Class C for high level.
Let's take for instance the H230 low level airway between HIJ and USOKO. If we plan a route at FL140, according to SkyDemon this segment will lie entirely outside CAS (or OCAS for short). You can see this by looking at the vertical view on the bottom.
However, if I go to the AIP it says the following:
The airspace is Class D and controlled by Sevilla or Madrid ACC
Shouldn't SkyDemon hence display a "tube" of CAS around airways, just like it does in Scotland for instance?
