SkyDemon running on a Navigon 70
http://forums.skydemon.aero/Topic3283.aspx
By The Flying God - 6/13/2011 3:43:32 PM
I am trying to get the 30-day free trial version of SkyDemon running on a Navigon 70 device. The current PNA software doesn't allow me to drop into the WinCE interface so I have installed MioPocket Mini 4.0 on a MicroSD card. I can now get the system to boot into MioPocket.
Now when I click on SkyDemon I get an error that "mscoree.dll" does not exist. My research has led me to believe that this is something to do with WinCE .NET which is probably not installed.
Does anybody know how to get SkyDemon working on my Navigon Device or failing that how to install .NET on the device?
By BJ - 6/14/2011 12:33:56 PM
Can you get your device to connect up with your PC using Active Sync/device manager? If so update .NET that way from Microsoft but be aware if you completely power down the unit it might put you back to square one.
I've also experienced differences dependent on which version of MioPocket is used although this was a while ago. Once I got it to work I left it alone so my version is quite old (Release 56).
Cheers BJ
